FRONT BEARINGS
Old 11-14-2003 | 09:24 AM
1ST CUMNZ's Avatar
FRONT BEARINGS
I'AM GOING TO DO MY FRONT BRAKES ON MY TRUCK.CAN ANYONE TELL ME WHAT DODGE RECOMMENDS ON PRELOADING FRONT BEARING,WHEN U TIGHTEN THE NUT FOR AXLE?
Old 11-14-2003 | 07:40 PM
Scubasteve's Avatar
Re:FRONT BEARINGS
I keep thinking around 140 to 150 ft lbs on those. You really arent preloading the bearings. The preload is set by how the bearing is made.
I know they were tight as heck when i took mine off and remember setting them at 150 ft lbs.
Hopefully someone will confirm this.
Jason
Old 11-15-2003 | 05:55 AM
berner's Avatar
Re:FRONT BEARINGS
Both my CD and my Haynes say 175. Then loosen or tighten to the next nearest cotter pin hole. The front wheel bearings aren't serviceable unless you have a press. They come as an assembly if they need replacing.
If the rotors and U-joints look OK, I wouldn't bother taking the hubs off. The axle seals tend to leak after if you don't support the outer ends of the axle really good. You don't want to be changing those. They go in from the inside of the diff. It's a stupid design. Almost seems like they did it to make money off of parts and labour.
Old 11-17-2003 | 12:53 PM
1ST CUMNZ's Avatar
Re:FRONT BEARINGS
THNAKS FOR ALL THE GREAT INFO GUYS
Mutt68
09-25-2012 12:51 PM
jetsnow
09-10-2006 12:09 PM
TEXASTURBO
03-30-2004 11:27 PM
1ST CUMNZ
03-05-2004 05:41 PM
johnh
10-20-2003 05:33 PM
Quick Reply: FRONT BEARINGS
