flip out mirrors
flip out mirrors
Im looking for a set of flipout mirrors for my 1996 ram I know 96 to 01 are all the same anyone have any used 1's for sale or maybe a part number I have seen them just cant rember where
thanks Steve
thanks Steve
You probably wont find used... they only came on second gens during 2002 I think...and not very many. The mounting bracket on the third gens is too big. You'll have to buy these.
http://www.kool-vue.com/lookup_detai...0&id=2001&pg=2
and youll also need the mounting brackets to keep them from vibrating too much.
Scott
Scott
Go to a U pull yard and find a Dakota. They are easy to find. The swing out mirror bracket is different but if you disassemble the bracket down to the bare pipe and reassemble it with the 2500 mounting hardware it works great. I found a 93 Dakota with power mirrors and upgraded my 2500. Had to grind a slot in the 2500 bracket for the wires to pass through but it works and looks factory. Got both for 20 bucks. If you go power don't forget the mirror switch(the Dakota switch is same if you remove the bracket). It is simple to wire.
Canuckville
08-24-2009 06:29 AM
