fixed pax. side window switches
When we bought the truck last May, the passenger door window switch was inop in both directions.
Removed the door panel and removed the switch assy.
Brought it inside and proceeded to clean the contact points with 400 W/D sand paper.
Reinstalled, only one side was working.
Removed the switch assy. Cam arms fell out and it took a few minutes to locate them in the gravel. Brought them back inside and reassembled the switch assy.
Finally, I cut small square pieces of electrical tape and built up the contact surface to the cam. Window works well in both directions, in fact, I had "a auto down" for a few cycles of the window.
Window has worked well for several trips now.
This might help someone to repair their door window switch problems. Might even save some money.
This should work as well with the door lock controls.
hhrumph
hhrumph
vavtx
03-04-2006 10:22 PM
