Either full AC or Heat, no mixing happening?
Either full AC or Heat, no mixing happening? I thought I saw something about a mixer door? Am I barking up the right tree?
Are you talking about when you turn the switch to adjust the fan control, you either have full ac/heat or none at all? if that's the case, there's a resistor that screws in below your fan, two screws, and a plug in connector. If you pull that out, there's a good chance that's burned up. It's about a 60 dollar part from the dealer. I just had to do that to mine, and it fixed my issue. I had the same problem. If you need pictures, let me know, and I can try and take some later.
Mode door adapter cracked/broke. Drop the mode door actuator off, pull the adapter off the bottom of the door and you'll most likely find it broken. I still have one in my tool box from "back in the day".
I ordered a pin from HeatTreater that should be here tomorrow. I guess like you said the pin breaks off and the blend door just spins in circles. Thanks for the help.
redlineguy
15
01-09-2012 09:15 PM
13bdarren
01-27-2009 12:39 PM
West Coast
07-04-2007 10:25 AM
j
11-14-2003 09:38 PM
