Does my Dodge RAM have a rear brake proportioning valve?
Old 05-24-2009 | 06:13 PM
mstep3's Avatar
Hi,
I'm a little confused if my truck is equipped with what is called a rear brake proportioning valve.
I've got a 2002 RAM 2500 CTD 4x4 with 4-wheel disc anti-lock brakes. Did these trucks use this option on them for the rear brakes?
Also, if it is used....does the raising of the rear of the truck 1-2 inches affect the abs brakes or this valve?
Thanks,
Mike
Old 05-24-2009 | 08:24 PM
Number47's Avatar
i was just under my truck and i have the big drum brakes and i didnt see one on mine but i wasnt looking either
Old 05-24-2009 | 08:35 PM
dkenny's Avatar
with 4 wheel abs..I don't you'll find it.
without 4 wheel abs yes..I have a 99 and an 00 and both have the valve.
I would think that raising the truck without re adjusting the rod to the valve would be an issue.
-dkenny
Old 05-25-2009 | 03:59 PM
mstep3's Avatar
-dkenny
Thank you for the information. I was wondering. Where is this usually located on the rear of the truck if a Dodge RAM does have this?
Old 05-26-2009 | 09:56 PM
dkenny's Avatar
mine are located just above the rear axle drivers side and mounted to the frame. there's a arm the fastens to the axle..I found this on my '99 because the rear lines leaked..rusted through..
-dkenny
Old 08-08-2009 | 08:51 AM
heykw's Avatar
would a 96 2500 have the valve or did they start in 97?
Old 08-08-2009 | 04:47 PM
mstep3's Avatar
mmmm...i'm not too sure about that....you may want to get the advice of someone that is familiar with that year.....i do know that if you truck has 4 wheel anti-lock braking system that it does not have this valve....
Old 08-08-2009 | 08:01 PM
infidel's Avatar
The load sensing valve in the rear didn't start until '97
Old 08-10-2009 | 10:45 AM
bentwings's Avatar
My 99 dually doesn't have the valve.
pigeonman
03-23-2018 12:12 PM
Thedieselkid
05-22-2008 02:55 PM
royta
02-08-2007 08:54 PM
Bobcat698
15
08-08-2005 10:53 PM
