do i have a charging problem ???
when i first start my truck ( doesnt seem to matter if cold or up to temp ) although the prob seems to last longer when cold... there is a draw on the engine ( kind of like the a/c kicking in, but it isnt ). the volts go down to to the mark on the left side ( about 11 or 12 volts i guess) for a few momments then goes back up to normal. it will cycle like this for a few minutes then eventually stops. the lights go dim and then come back to normal. you can actually hear the draw on the motor. and it also does this if it was plugged in or not, doesnt seem to matter. so tell me guys what is it ??? alternater going bad ???
Re:do i have a charging problem ???
[quote author=MnTom link=board=5;threadid=23810;start=0#msg224351 date=1071586657]
You have nothing to worry about. The draw is nothing more than the grid heaters cycling. It is entirely normal.
Tom
[/quote]
Ditto-
Tom
[/quote]
Ditto-
i kind of thought thats what it what it might be but hey it never hurts to get a 2nd opinion right...i didnt notice it much last year but then again i bought the truck towardsr the end of the cold stuff around here. why do the grid heaters cycle even after the truck is hot though ( or up to temp ) thanks again guys, scott
Grid cycles because....
[quote author=dieselcrazy link=board=5;threadid=23810;start=0#msg224361 date=1071587021]
[/quote]
Your grid heater has a thermistor (think temp sensor) in the intake manifold. It will cycle any time the intake temp is low enough- usually below 65 degrees. You might check your battery connections. Grid heater cycling is normal, but if your battery connections are foul, the voltage drop is greater, making the meter and light dimming more noticeable.
[/quote]
no prob d-train. i just havent been online much as of late and when i did a quick search i came up empty handed.....may have been a spelling error in the search field. so like i said i thought that was the grids but didnt realize they would do it even when up to temp peace ??? lol lol lol scott
Re:Grid cycles because....
[quote author=HammerMTB link=board=5;threadid=23810;start=0#msg224367 date=1071587697]
Your grid heater has a thermistor (think temp sensor) in the intake manifold. It will cycle any time the intake temp is low enough- usually below 65 degrees. ..........[/quote]
Cycling shuts down once your speed exceeds 15 mph, but will reset if the ignition is shut off and then restarted regardless of the engine or water temperature.
Diesel-Dan
20
09-22-2019 09:34 PM
GLHS
02-25-2011 10:12 PM
