Difference beween wax coat and e-coat frame
I don't know if I would consider that entirely true. Yes, location does have a large influence, but the electroplated process is much better than wax coat. In fact this is a facet of industry that has improved greatly the last ten years. The plated process for frames and steel body panels is much better. We will probably much less rust on newer vehicles.
Anyway, my truck lived on dairy farm for 10 years. It has seen its fair share of manure and salt. I have rust all over the body panels, but the frame is in pretty good shape. Now, I don't have a wax coated truck, so I don't have a direct comparison. I don't have an orange frame though.
I'm not trying to argue, these are just my observations and opinions.
- Craig
- Craig
yeah- living in the salt belt, believe me, the ecoat holds up much better than the old wax coatings. My 96 has been plowing and parked daily on dirt since new- up here you don't see 11 year old plow trucks in the condition my ram is still in- they're all rotted away while mine is just starting in the door bottoms and front drivers fender lip. Ecoat is a definite improvement.
Well MY wax coat frame is rust-free.
We're talking about frames here. Doesn't apply to wheel wells, doors, or fenders. So all those rotted trucks you guys are talking about have nothing to do with the frame.
Besides, as far as the weather in Bakersfield the only thing attacking your truck is salt air... compare that to a New England truck and you'll have a rusted out hulk with a few bits of wax remaining.
Someone correct me if I'm wrong here, but I do know that an e-coat process requires the part to be dipped into the paint. It would be tough to dip just the bottom half of trucks. My 94has 220K of salt and 3 years of plowing under its belt and my frame is still looking pretty darn good. Nothing is rotting away , just light surface rust and it isn't even the bright stuff. How the vehicle was taken care of while in the salt belt has a great affect as well.
Spent some time under my made in Mexico 97 today, and it appears to me to have the e-coat on its frame. There is a black finish on the entire frame that looks similar to the blue on a firearm, it doesn't appear to be painted on and I don't believe its wax.
The truck has not been driven much during the winter months, so there is almost no corrosion at all on the frame or the underside of the truck. The underside sheet metal appears to have only paint on it.
While true washing the truck will prolong it in a salt environment- most plowers do not. Matt, while you live in the salt belt, remember the 3 years of plowing on your truck is the equivalent of 10 years of normal vehicle driving winters- plows drive in the worst salt conditions- the slush created when the roads are being salted.
If you have wax you'll know it- it doesn't look or behave like paint- it looks and behaves like wax- it's soft and easy to dig your fingernail into.
Actually, the E-coat is short for electro-deposit. The chassis is run through a bath dip of cleaner then either dipped with a charge in a solution (like electro plating, or sprayed with charged paint- as in the chassis is connected to a neg pole and the gun is positive (current flows from pos to neg) kind of like powder coating. The charge on the chassis makes the coating adheare better AND draws it into the cracks and crevices regular painting would not.
48snowman48
03-20-2008 09:14 PM
BigBlueDodge
37
08-16-2005 02:32 PM
