Day time running lights
I have a 98 2500 that the day time head lights stay on unless batteries are unhooked where do i find the running lights modual. The bright lights indicator is on in the dash no lights on. TKS IF CAN HELP
Sounds like the module is toast...Same problem as I had...The module is located under the hood,attached on the drivers side inner fender well...Can't miss it.Black box about 4inchs long and 4 inchs wide...
just unplugging it will make everything work normally except no DRL and NO hi-beam indicators, you can jumper pins 3 and 6 and the indicator will work again, daniel stern sells a 40 $Park light DRL takes 10mins t0 wire up and works slick
here is what it looks like with park lights
this is with the DRL
KWKING
10-04-2006 09:40 AM
