Corrosion from Mag and salt... sacrificial anodes installed
Basically, this is what will happen . I believe you have seriously worsened your situation. Talk to people who operate aluminum and steel trailers in salt roaded conditions, the reaction eats the aluminum and then rusts the metal. Good trailer manufacturers will isolate the aluminum from the metal.
In fact that is where I initially saw how effective it was - found pictures on rv.net that showed an aluminum trailer with holes corroded around steel fasteners, just over the course of one winter (not that I didn't know about the sacrificial anode method before that, just never thought of it for a truck).
-P
You may be on to something here for northern trucks. Let us know how it goes. It would be interesting to have two samples on the truck, one bolted directly to the frame metal to metal and one bolted to the frame but isolated from the steel frame. Then see which one eats away the fastest without eating the frame.
Just a plain ole guy
This makes no sence. If some rood salts got splashed onto the back of the frame near the spare tire, a chunk of aluminum bolted to the front of the frame isn't going to magically have enough control over corosion to make that salt not do anything. What's going on is a chemical reaction between the salt and the metal where it happens to be splashed upon, not any kind of electrical erosion that an anode can stop.
-P
the metal to be protected and the place(s) where the electrically contrasting metal is installed must have electrical continuity through the electrolyte (as in, wet all over), in order to complete the circuit.
I use them on my boat to protect the submerged aluminum parts on the motor & they work great for that - because they're SUBMERGED - can't see how this would ever work on a truck.
That is the whole idea. In this case I will be happy to let it eat the aluminum and only then move on to the metal. "Electrolysis" due to dissimilar metals causes exactly that, dissolving of the more active metal first.
-P
-P
However you are attracting more corrosion in that particular area. Full aluminum trailers do better around here than aluminum and steel. I understand your basic thought process, the issue is the aluminum will not slow down the rusting of the metal in that area and be sacrificial, it will in fact promote it. Just my 2 cents.
I think you're setting yourself up for galvanic corrosion in a big way. Two dissimilar metals with a dielctric (moisture) inbetween will instantly begin the corrosion process. This is why we use aluminum washers under steel fasteners on aircraft. Just my two cents..
Nothing will happen, other than what you bolted to your truck will have the same stuff on it. An anode is to combat an electrical reaction between unlike metals, or like when water is stored in a tank, like a water heater. What you have is salt or something else sloshed all over your truck. The stuff aint gonna decide that becasue there's something bolted to the frame to magically not corrode anything.
From Wikipedia:
Galvanic corrosion is an electrochemical process in which one metal corrodes preferentially when it is in contact with a different type of metal and both metals are in an electrolyte.
It will corrode something-- the anode. That's why these are called "sacrificial anodes" and they are used in the marine industry all the time.
Good idea, Paul-- I might need to try this myself.
Justin
I am inclined to install magnesium instead, if it does corrode it will corrode faster and I want to post some photos for the guys here Walmart has those Mg fire starters for $6, looks perfect for the job (oops, I just caused a nationwide shortage of them!). Just don't drill it dry at high speed, anybody, or very bright sparks and quickly propagating fire may result
-P
-P
ELECTRO-CHEMICAL is the key phrase there. There is no chemical reaction without corresponding electrical activity.
From Wikipedia:
Salt water is an electrolyte. Hence, you have a "galvanic" situation when you bolt a zinc anode to your steel frame. It will corrode preferentially, as defined above.
Justin
From Wikipedia:
Justin
Will work in salt water only! You guys kill me, anyways, rust your trucks, it's up to you. I'll oil spray mine.
1 Post
Oil works great, not that environmentally friendly then again neither is the salt.
Rinse your trucks weekly in the salt belt. Wire brush and paint them in the summer.
Don't rinse your trucks at these do-it-yourself car washes because most of them use recycled water loaded with salt of the hundreds of cars before you!
Last but not least, don't park your truck in a heated garage after driving through the salt spray because the heat will double or triple how fast things will rust. This is why it is very important to rinse right away on late spring storms when the temps can rebound quickly when the sun comes up.
PC hit the nail on the head, the aluminum will cauz the frame to rust out, why do u think zinc is used as a sacrificial anode on boats ? W.T.F.** this isnt rocket science.............or is it...........for some.........please for the lack of a better term........idiot......take the aluminum off.
I didn't put it on your truck, did I?
