Color of power wires for door lock?
Old 08-15-2013 | 01:48 PM
unioncreek's Avatar
My passenger door lock will not work from time to time when I unlock it from the drivers side. What color are the wires or where can I find which wires feed the passenger door lock?
Bob
Old 08-15-2013 | 05:52 PM
CarlJensen's Avatar
On my 95 the right door lock switch is fed from the left door lock switch. The wire colors are PK/VT and OR/VT. On the right door lock switch you also have power from fuse 19 coming in on a Red wire. Fuse 19 feeds both door lock switches and the two switches are in parallel with each other so if you hit either switch they will both lock. On the right side the wires that feed the motors are colored PK/BK. The PK/BK wires are routed to both lock motors for power. Hope this helps. Don't know if yours is the same.
Old 08-16-2013 | 10:29 AM
unioncreek's Avatar
Thanks. My right switch doesn't work at all to lock or unlock either doors. Hopefully I'll have time this weekend to check it out.
Bob
Old 08-16-2013 | 01:22 PM
CarlJensen's Avatar
Other thing I forgot to mention, the switches do get dirty and corroded inside. They can be opened up and cleaned but I replaced mine to be sure. Swap a switch first or jumper around it before you chase wire. The wires do chafe sometimes and break where they bend at the door flexible feed through tube.
mattyfz450
09-16-2009 08:40 AM
Dynocon
03-04-2008 09:32 PM
staarma
0
10-25-2007 01:49 PM
feveree40
10-03-2007 04:59 PM
GlennRMK
04-14-2006 07:56 PM
Quick Reply: Color of power wires for door lock?
