Center Console Stuck
mine does this to. i just push the button and lift the whole console some and start jerkin and wigglin it. always opens then
oh i just saw you got a quad cab, mines regular cab.
I assume you're talking about the overhead console? If so, yeah, they can sometimes be real hard to get out. My last truck's was real easy, but my new one is hard. I think I used the back of a hammer to yank that $(!&er out.
As I recall there is some sort of balancer in the latch mechanism so that it won't open when in the lifted position. When I had this problem I just lubed it up and had no problems with it afterwards.
mishkaya
mishkaya
mishkaya
mishkaya
BTW how did you lube it up? Is there a way to open up the latch assembly to clean and lube?
Don't remember how I did it as this was some years ago. I just remember I got so frustrated with it that I spent the day and tore it apart to see what the deal was and managed to lube it and get things put back together.
mishkaya
mishkaya
I tried lubing it from the outside and determined that it is not the vertical/horizontal switch causing the problem. In the horizontal position I can depress the button with no result. In the vertical position I can not press the button because of the position latch.
mishkaya
mishkaya
Did you spill a soda?
I did, I needed to pretty much douse the thing in Stoners invisiglass. I used glass cleaner because it evaporated fast and didn't seem to melt plastic. After I got it loose large amounts of spray silicone lube seemed to do the trick. I do have to slap it sometimes when it sticks though. I should take the whole thing apart and flush it, but I'm to lazy
BlackSheep5
12-20-2007 03:26 PM
