Can't get steering wheel straight
Over the weekend I put in a new trac bar, shocks and steering stabilizer. When I went to test drive the truck Dodge on the steering wheel was vertical instead of horizontal so the steering wheel was not centered. I did a search and found that I could center it by adjusting the drag link. Well I have adjusted several times to center, drive the truck and then it is off center quite a bit, not as bad as when I started.
Before I go replacing parts in the front end thought I would ask what may be wrong. Is the drag link worn out? Tie rod ends?
I did check the alignment and it is close 1/16 off.
So I'm at a lose of what could be causing this.
Any info is appreciated.
Look for what is different (besides play obviously) between old & new. If new track bar is same length as the one you took out, no changes should be seen in the steering wheel position. You are correct. Adjustment is in the drag link. What track bar did you install?
I don't know about the '95s, but mine has an adjustable steering wheel bushing that is just for straightening the steering wheel. Always drove me crazy getting an alignment and the steering wheel is 1/4 turn off. Then the Service Manager of the local Tire Kingdom showed me the adjustable bracket off the pitman arm....
It's a collar around the linkage that, when both bolts are loosened you rotate one way or the other and it lengthens or shortens the steering linkage. It only centers your steering wheel and doesn't affect your alignment at all....
It took me at least ten times to get mine straight after putting the front suspension parts on. I thought I had it in the shop and then take it out on the highway and its off. Try again and went too far the other way. Got confused on which way to turn it. Went too far back the other way. For me it was hopeless getting it sitting still. Make tiny adjustments and cruise on a good straight road and be patient, you will get it. A few beers should help.
Got it Made little adjustments and ran the steering wheel lock to lock then make a little more adjsutments and finally got it
Is it me or is this a pain?
It is for sure. I got pretty aggravated with mine and I wasn't kidding about taking 10 tries at getting it on the money. I had it close several times and couldn't stand it being off even slightly. So I would go just a tiny bit more, too much, went too far dammit. The beers do help though.
here is the obvious loser way to do the adjustment. Because I'm lazy
make sure your adjustable track bar has the axle centered.
drive the truck forward, with the wheel centered properly. Mark the dash with a piece of electrical tape, in line with the center of the wheel. Drive in a straight line, and stop. Leave the wheel unlocked. Put a piece of electrical tape around the rim of the wheel, in the center at the top.
Get under the truck, loosen the locking bolts, and rotate the collar on the drag link, until the two pieces of tape line up. Tighten the bolts.
Drive into the sunset.
Any reliable professional shop would not return a vehicle back to it's owner until the wheel was centered as it should be. Very easy to do when you have it up on the rack.
