Can I use the stock trackbar?
I recently installed Carli 2nd Gen coils on my truck. The coils are the ones that Carli uses on the Hemi trucks. I would say that there's about a 2" or little more lift in the front over the factory coils. I was wanting to get a little more lift in the front so I went with some 1.5" spacers from TopGunz.
The question I have is: Can I still use my stock trackbar after installing the spacers or will it create problems? I'm hoping that it will lift the truck up to at least 3" but it will probably be more like 3.5" or more.
I am using KORE drop blocks for the swaybar & I also have Bilstein 5100's so I think I'm safe in those areas, but I'm not sure about the trackbar.
Thanks,
Mike
Thanks,
Mike
I was thinking that I would need a new one. I think that I'm already starting to experience problems because the stock trackbar isn't adjustable. I believe the front axle must be off center because the truck seems to want to pull to the right ever since of changed my coils. i've had an alignment done, but it didn't seem to help the pull to the right side.
yes, in order to center the axle w/the truck, you will need an adj tb or a track bar drop bracket. Like stated, you might have been able to get away w/it w/only the springs but w/the spacer your @ roughly 3.5" of lift.
Do you guys recommend the Thuren Trackbar for 2nd Gen trucks? I was taking a look at this one & though it would be a good one. Are there others that you would recommend?
http://www.thurenfabrication.com/stocktb.html
Rednecktastic
15
05-25-2009 07:05 PM
Captain
17
02-17-2008 12:49 PM
