A/C Recharge Question.
Old 04-17-2007 | 09:13 AM
Little-bit's Avatar
I tried to put a can of R-134A in my 2002 dodge. I used the low side port located on the passenger side next to the air filter. The system would only take a half a can?? The pressure on the system cycles between 25 and 45 psi. The compressor cuts on and off every four seconds or so. I tried keeping the RPM’s at 1500 with the recharge kit connected to the truck. I am not sure if I am using the correct low side port. Is there another low side port?
Old 04-17-2007 | 01:10 PM
clutch1's Avatar
whats wrong with the a/c? whats the ambient temp? whats your temp from air vents? really would help to know high side psi.
Old 04-19-2007 | 06:11 PM
Little-bit's Avatar
I don't have a set of gauges for the high side. The a/c over time just quit cooling. I added 1/2 a can R-134A. Now the a/c blows cold again. I am wondering why I could only put 1/2 of a can in the system.
Old 04-19-2007 | 06:15 PM
dodgezilla04's Avatar
did you invert the can? try warming it up by putting it in hot water before attaching the hose and trying to fill it.
Old 04-19-2007 | 07:16 PM
clutch1's Avatar
keep the can warm and use lipuid its faster just keep the low side at 50psi and lower while filling and if you need to, jump the low pressure switch but kinda hard to watch without high side
Old 04-19-2007 | 08:28 PM
ironbutt's Avatar
It's also hard to hear any flow from the can with the rattle of the Cummins . It's hard to heat the can while it's hooked up too..
Old 04-19-2007 | 10:13 PM
clutch1's Avatar
can you hear flow from a can? you think your 5.9 is noisey, try a Steiger at 1500. holding the can in front of the fan works ok.
Onemoparnut
06-05-2009 09:13 PM
AJMartin0321
06-18-2007 12:11 PM
crossy
07-26-2006 08:17 PM
ozzie
09-29-2004 09:50 PM
bigdogtruck
07-20-2004 06:21 PM
