A/C Compressor clutch replacement procedure
What vehicle?
If you are talking about a CTD, yes, kinda, you have to take out the bolts and tilt the compressor down, so you can get puller in there to pull the pulley.
Need special wrench to hold pulley/clutch face still while removing nut in center, i think its called a spanner wrench.
becareful not to loose any washers(shims) when pulling assembly off shaft. Shims are behind the assembly.
bradler
02-19-2009 10:53 PM
docram
11-07-2006 11:16 PM
Tommy93w350
07-07-2006 01:35 PM
Buffalo
05-25-2006 11:33 PM
