Broken power seat
My drivers seat also had a binding problem going forward or reverse. The small drive cable was slipping where the solid square input end to the flex cable was attached. The cable is driven by the motor. You can't buy just the part. It is sold with the seat assembly for about $400 from the dealer. I went to the hardware store and bought a piece of square stock and cut it to the length as the cable. With a little playing around with track adjustments I got it working. I could have brazed the cable if I had the tools. Anyway check the drive cable. The small motor under the seat drives the right and left tracks and must be equal across to prevent binding. I just frosted me that the drive cables were not available as a separate part fron the seat track assembly.
Bottom line: Probably best just to replace the motor if it's exhibiting this behavior.
thanks for the info!!
like other have said, i took my seat out, and was unable to find a way to remove just the motor, so I cleaned it up a bit, brushed off the dirt, re lubed every thing and got minimal improvement. i think ill just live with it for now, i dont change it much anyway im the only driver.
now the ball goints and steering parts have become priority as well as a TST #5 power kit
Thanks this was helpful!
My drivers power seat was kinda screwed up. The front tilt lever mostly worked fine. The rear tilt lever would go up, but not down. (Pushing down on the middle toggle would fix that though.) The middle toggle would go up and down fine, but would only go forward not back. I thought about reversing/switching the connectors or motors, but tried something else first. I removed the switch assembly from the seat. I pulled the connector off and then pulled off the faceplate to reveal the contacts. (Watch out for that spring and plunger thingy. It'll fall out and you'll have to sit down, mumble, and figure out where it came from. I put it into the hole in the backside of the middle toggle. That looked right.) Once I put it all back together every switch operated the seat as it should. (Yeah!) It sounded like there was gravel in the gears when it moved the seat back and forth, but at least it moves back now. Shoving my six foot frame into that seat for the 200+ mile trip home with the seat moved halfway forward was a bit of a drag.
Hopfully this helps someone in the future!
I am needing help with this now. I just bought a 95 with a power seat and it didn't move at all. I unbolted the seat and cleaned stuff up and I still cannot get the seat to move forward or back. I can see each end of the drive shafts spinning but it isn't turning the threaded tracks.
DezertBum
03-10-2010 03:00 AM
Rpainter
21
03-08-2008 02:36 PM
Common
07-27-2006 09:46 AM
