Body lift???
Old 04-04-2003, 06:47 AM
Evildiesel's Avatar
Re:Body lift???
As one final note addressing the gap between the body and frame, Performance Accessories (the body lift co.) also makes "gap guards" that extend the inner fenderwell to cover the gap. I bought them but have not yet had a chance to put them on, and will post photo's when I do. :P
Old 04-04-2003, 11:41 AM
Muted User
Superduty12v's Avatar
Re:Body lift???
Haulin, Noticed you changed your sig... did you finally get that NV5600 installed? If so, How's it rolling?
Old 04-06-2003, 02:22 PM
Haulin_in_Dixie's Avatar
Re:Body lift???
Yep, lost the pilot bearing on the clutch so had to tear it down. Works good, had to make an adaptor for the rear mount. It is an improvement pulling, much easier on the engine. Now if I can ever learn to smoothly shift into forth on an upshift. I am going to write my opinions in a thread when I get a chance, there are great differences from the five to the six.
Old 04-06-2003, 07:42 PM
97CTD's Avatar
Re:Body lift???
hey fellas where did you get your body lifts?? how much and got any links??`<br>
Old 04-06-2003, 09:40 PM
Rob Thomas's Avatar
Re:Body lift???
Here ya go.... http://www.ntwonline.com/ntw0799/pages/bodylifts2.html<br><br>Just don't tell them it's for a diesel.<br><br>Later, Rob
Old 04-06-2003, 10:37 PM
Re:Body lift???
But Rob that does not go over 1998. :'(
Old 04-06-2003, 10:45 PM
Rob Thomas's Avatar
Re:Body lift???
Maybe they need to update the site, I ordered mine there and it fit. Shouldn't be a difference anyway.<br><br>Later, Rob
Old 04-07-2003, 10:27 AM
97CTD's Avatar
Re:Body lift???
I saw evil said he put in electric fans as opposed to relocating the shroud are electric fans better if not wha tall is involved in relocating the shroud??
Old 04-07-2003, 10:08 PM
Rob Thomas's Avatar
Re:Body lift???
Not sure about the shroud, I have electric fans also.<br><br><br>Later, Rob
Old 04-09-2003, 06:53 AM
Evildiesel's Avatar
Re:Body lift???
[quote author=97CTD link=board=5;threadid=13008;start=15#125086 date=1049729252]<br>I saw evil said he put in electric fans as opposed to relocating the shroud are electric fans better if not wha tall is involved in relocating the shroud??<br>[/quote]<br>Drop down brackets are used to lower the shroud, however I think that you may not me able to since your coolant bottle and winshield fluid bottle would come into contact with the intercooler lines on the way down. they practically sit on top of it as it is. As far as electric fans being better, They do not flow more than the stock fan, But niether Rob nor I have had any probelems with overheating, and he tows more than I do and has fans half the size, so I cant say for sure whether or not that would be an issue. You could also simply cut off the bottom of the shroud so it doesn't contact the fan when you lift it, that would probably be the cheapest way to go wthout affecting anything else.
Old 04-09-2003, 06:57 AM
Evildiesel's Avatar
Re:Body lift???
[quote author=97CTD link=board=5;threadid=13008;start=15#124887 date=1049676131]
[/quote]
I got mine and my gap guards from Macromotive
www.macromotive.com/
Had to call them to place order though because specific model #'s werent listed and I wanted it right the first time. You can get a shifter extension for your 5-spd here too
Old 04-09-2003, 04:50 PM
SmokinShaker's Avatar
Re:Body lift???
This is and will always be one of the most controversial topics with lift kits. I have installed many suspension lifts and body lifts and *PERSONALLY* I would go with a suspension lift. But then I actually use my truck offroad and get it in to some pretty hairy situations where I need the stability, strength and flex of the suspension lift.<br><br>As for the body lifts, I HAVE SEEN a truck slam on his brakes and the cab bolts broke in half sliding the cab half way off the frame and trashing the doghouse. I HAVE ALSO SEEN trucks in offroad situations where there was too much stress put on the bolts and they broke.<br><br>Having said this, I know a LOT of guys running PA body lifts on Rams that have had no problems at all and wheel theirs in the same way that I wheel mine. The PA body lift is much more reliable than in past years. All of the incidents I've described were on older trucks so....FWIW<br><br>[quote author=Evildiesel link=board=5;threadid=13008;start=15#124105 date=1049460432]<br>As one final note addressing the gap between the body and frame, Performance Accessories (the body lift co.) also makes &quot;gap guards&quot; that extend the inner fenderwell to cover the gap. I bought them but have not yet had a chance to put them on, and will post photo's when I do. :P<br>[/quote]<br><br>I installed a set for a bud on his Chevy and let me tell you...save your money! These things are crap! The back ones were close enough that we could make them look ok but the fronts were not even close to fitting. Plus, with the newer Rams you don't even need them because of the plastic wheel wells. <br><br>Haulin-<br>For your truck I think you would be ok with the body lift. Just my opinion.
Old 04-10-2003, 06:09 AM
Evildiesel's Avatar
Re:Body lift???
[quote author=SmokinShaker link=board=5;threadid=13008;start=15#126146 date=1049925005]<br> These things are crap! The back ones were close enough that we could make them look ok but the fronts were not even close to fitting. Plus, with the newer Rams you don't even need them because of the plastic wheel wells. <br><br>[/quote]<br><br>D'OH......anyone want to buy some gap guards? Real Cheap?<br>ahh I'll list em on Ebay...they buy anything on Ebay..
Trooperthorn
01-07-2011 12:55 AM
jj3500
07-12-2009 03:59 PM
Red_Angus
03-23-2008 09:18 PM
cah
04-22-2003 12:26 PM
Quick Reply: Body lift???
