Blowing fuses need input.
All of a sudden as of 2 weeks ago I keep blowing door lock fuses,I change the fuse and it works for a while before it blows again,has anyone eles had this problem and any possible causes?
Thanks guys..
Thanks guys..
Well I can't find anything out of the ordinary,I took the door panels off and it is bone dry in there,I do know the fuse gets pretty warm.
When I first got the truck in Jan. 2000 I had a problem with fuses under the hood kept blowing,they replaced the fuse box under the hood and problem went away.
May have to take it to the dealer
to get it fixed..
![Frown](https://www.dieseltruckresource.com/forums/images/smilies/frown.gif)
Hey Dave
I would squeeze the wires where they go from the door to the cab and see if that may be a cause of your troubles. It worrys me a little bit that the dealer had to replace the whole fuse box to find a short in the system somewhere. By the sounds of it they didnt really find the problem and instead they maybe just moved the wires around causing the problem to go away for awile. Need to move some of the wire harnesses around near the fuse panel to and watch the fuse to see if it pops again.
Good Luck
Jason
Good Luck
Jason
Originally posted by Scubasteve
Hey Dave
Good Luck
Jason
Hey Dave
Good Luck
Jason
Had the same prolbem with my truck after I first got it found out it was a wire rubbing on the clutch assembley under the dash (grounding out) Check under the dash have e look around at all the wires and see if you can see anything. Could be in the wiring harness so look carefully
