best year dodge?
Old 04-14-2008, 08:26 PM
Common's Avatar
Originally Posted by Dave Miller
I have a 97 12v 5sp and love it. It has the dreaded 53 block with 225K miles on it and still running strong. I got my fingers crossed.
...And of course I've got to say the 97 12V from a salt free state is the BEST truck to have.
I can't take credit for picking it though. I picked my by dumb luck. A co-woker who is a TDR member suggested I look into a Cummins. So I bought it on EBay from Texas 4 years ago and had it shipped sight unseen and then became a TDR member. My first diesel. I guess I should buy a lotto ticket some day...nah...never have...never will.
I'm sorry man, but there is no way you have a 53 on your 97 unless you had an engine swap.
Old 04-14-2008, 09:15 PM
kas83's Avatar
I wouldn't go as far as saying that. I've seen some pretty weird things on the 97-98 chageover trucks. My 97 is a 7/97 build date, and I know I have seen trucks with 9/97 build dates with the old style dash and that are titled as 97's. I also have seen an 8/97 build 98.0 12 valve. New interior and everything. Early build 98 12 valves and very late build 97's can have the 53 block if the 12 valve was indeed built using the block.
They had leftover 97 stuff, I doubt they would just toss the stuff. Hell, my boss has 12/99 build date 01 model. I wouldn't say there is no way on any of this stuff. I've seen it with my own eyes. Dodge does some wierd stuff.
Old 04-14-2008, 09:17 PM
Common's Avatar
This will be the first confirmed '97 truck EVER with a 53.
Old 04-14-2008, 10:24 PM
2500's Avatar
yep.. transitional years can result in unique combo's.
there was someone with a 98 12v short bed extend cab without little doors. almost all pre 98 CTD were long beds.
Old 04-15-2008, 05:46 AM
Common's Avatar
Well now that I've been corrected - the best year is a real () 97 12v.
I still want visual proof - I think we've all been waiting on this truck for years.
Old 04-15-2008, 08:22 AM
renopker's Avatar
Hands down 98 12 valve best of all the parts.
Old 04-15-2008, 11:35 AM
Dave Miller's Avatar
I do have a 53 block on my 97. Its very easy to spot on the block. That is one of the first things I learned about when I got this truck. I am the 2nd owner. The first was from Texas and had 120K miles when I bought it.
I don't know if the engine was replaced but everything looks stock. Whether it came stock with a 53 block I guess I'll never know. The CPL sticker on the gear case looks stock...CPL 2175. I don't know where block casting numbers are but that might not help either to prove anything.
I'll try to get a pic for you guys.
Old 04-15-2008, 01:12 PM
2500's Avatar
at first blush... that would appear to be true.. but when you dive in further. 98, 1/2 year engine had a number of features to itself.
look at size of 98 factory service manuals... it's double the size to cover all the changes.
97 got the hydro-boost brakes and 47RE later years got with all the bugs worked out.
if one has small children, those mini-doors are a lifesaver! my youngest boy was 12 when I got my 97 and he had no problems climbing over the front seat.
so it really gets back to individual needs. if it's someone main ride with small children. hands down 98 would be better. kinda of like short beds vs long beds.... depends on the person.
bottom line is both pre-97 and 98 are pretty much trouble free CTD models.
don't get me wrong.... 12v need maintenance like anything else. like wheel brgs, ball joints, alternators, starter, U-joints, AC compressor, water pumps, etc, etc, etc.
Old 04-15-2008, 04:58 PM
jeepeater2003's Avatar
I gotchya. Sounds like most like the 12V around here.
I am looking at a 98.5 24V right now so wish me luck. Then ill get an airdog and an adrenalane....
Old 04-15-2008, 11:50 PM
xzaq103's Avatar
Just make sure its not a 53. I would also check the fuel pressure before i bought it.
Old 04-17-2008, 09:43 PM
dweller's Avatar
I vote '02.
Old 04-17-2008, 10:34 PM
dieselman2300's Avatar
1997 12 valve I'm partial to!
Old 04-17-2008, 11:50 PM
ironbrew's Avatar
Sorry. I just have to ask... what is the killer dowel pin? I have a 94, and have had a bit of work done, but nobody has mentioned a killer dowel pin... mind you, I don't hot it up much... it stands on its own pretty good.
Thanks
Old 04-18-2008, 12:16 AM
Cougsfan's Avatar
Just do a search on "killer dowel pin", Ironbrew. You come across 100's of posts about a alignment dowel pin that has a not so small chance of falling out of the timing cover and wrecking the heck out of all your timing gears and timing gear cases. It has a relatively easy fix to prevent it from happening
ssorange
05-31-2008 06:01 PM
OkieTrailRider
01-23-2007 05:23 PM
trophystock
07-16-2006 11:00 AM
Greguw
10-12-2005 09:58 AM
Wreckless
11-06-2003 09:19 PM
Quick Reply: best year dodge?
