Being Towed Question.
What is the correct way to Tow a 2002 4x4 Dodge diesel? Should the truck being running while any of the tires are on the ground and turning, to lube the transmission? Or is that not necessary. I really don’t know, seems like it couldn't be anything but good for the tranny.
The weight distribution is wrong when you tow backwards. You may end up in a ditch & learn how poorly the truck survives. But, feel free to take a video for youtube. Much more enjoyable to watch someone else screw up than to do the same thing yourself.
You talkin about actually towing, or just pulling it behind another vehicle?
When I towed mine I slung it from the front (only because the front hub was out) other wise I woulda wheel lifted it, since our shop does not have a rollback. But I was taught to always pull the shaft (and strap it to the frame to keep the tranny/t-case from leaking) regardless of distance just to be safe
Ex military, here ran a recovery section for 4yrs, 5ton to 10ton wreckers, pulling heavy stuff, never saw any issues towing from either end, the end you decided to tow from only made a difference if there was something physically wrong with the veh casuality (ie hub/wheel broke/or missing)
20yrs as a Military mechanic, never seen tow from the rear an issue unless it was physically impossible, and I've seen some pretty bizarar recoverys
My two cents
when my truck got smashed by a tire (is a post on it) I was recovered backwards, was towed 30miles on the hi-way back to the garage...it never ended up in the ditch or on Ytube
I pull mine regularly 30 to 150 miles at a time with a towbar by just putting the transfer and trans in neutral with the key in the on position to unlock the steering. If you're pulling it with a pickup make sure it is running so the power assist steering helps it follow or you will have a handful
i had to have mine towed and they told me that being a 4x4 and with it being the auto locking hubs that it always should be towed on a flat bed do to the transfer case would get torn up.
AWD vehs like say a Ford excape or Chev Equinox, would need dollys or flat bed,
Administrator / Scooter Bum
The three occasions that I have had my dually towed, I insisted on a flat bed truck.
I'm not willing to take a chance of burning up my Goerend's tranny.
Box5
07-19-2007 06:46 PM
tobyw
10-07-2002 05:49 AM
