Before I buy, I'd like some opinions.
Looks pretty good for 12,500 and not many miles. Definitely a tow rig. good tires. HO 6 speed, quad. You couldn't find that up here for less than 18000. The dash can be replaced/covered. It looks like the exhuast has been redirected and there's some wiring running to the fuel tank that doesn't look 'factory'. The oil looks like my truck does in that area. Is there a puddle under where its parked? Mine seeps but doesn't drip. Get it checked by a good mech and check the title history, you don't want somebody's Katrina survivor! Kurt
It's inside the column and what the purpose is I don't know. I do know that it has electronics built in it and it will break and then the cruise/horn/airbag will not work. There is a recall on it so call the dealer with the vin and see if it has been done yet...that's how I got mine fixed after I broke it trying to fix something else.
DTR question asker
Hmm doesn't look to bad... Box5 is gonna have a fit when he sees that side-dump exhaust :P.
The dash sounds like a common problem and probably shouldn't be a big deal... airbag light is most likely a bad sensor somewhere (or some other stupid broken electronic thing :P), my light is on too. Run/get someone to run a carfax on it for you... Hope this might help some.
Run it by a dealer, spend $100 and let them do a full buyer's check on it. Safest way to know what you're up against. I would also be aware of a possible salvage title, for the money, it seems a little "good to be true."
"Who cares about it being dirty"...well that's also a good indication of maintance habits and how much they care about thier truck.
Just a gut feeling but something tells me there is something major wrong with this truck. Get it checked out proffessionally and check for accident history. If it does check out good then it looks like a real good deal to me. Good luck, that's just the type of truck I would be looking for.
Mine has the same busted dash. The plastic can't be much thinner so the sun ready attacks it. Put a dash carpet on it and it becomes a very convenient place to pass wires up for things (i.e., GPS, gauges, etc)
See what kind of person the seller is. Use your intuition. If you feel like there's just something not right then don't buy it or get it checked out thoroughly. We got a really good deal (for the time) on our Acura a long time ago. Turned out nothing but problems and the seller had rolled back the odometer... I've car shopped several times in the past and have came to the conclusion that you get what you pay for. When we bought a Honda Accord, there were lots of cheaper pre-owned ones but there was just something not right about them. Don't let this thread give you second thoughts either though. Let us know what happens.
also, if a guy is on a limited time/money budget, sometimes fixing a weeping oil pan gasket just isn't in the cards... I'm more cautious of a truck that is perfectly clean than one that you can see some leaks! anyone can go powerwash their leaker before you come over!
Agreed. It's always a good sign to see tie rod ends and u-joints greasy, not clean. And to see a spatter of grease radiating around u-joints - if you grease 'em, that's what happens. Only the most particular people clean that.
dcwm
10-05-2009 01:26 AM
dcwm
09-29-2009 06:18 AM
desertchecker
14
02-18-2008 09:32 AM
GreenZ
13
02-06-2005 07:22 AM
93' Shorty
12-28-2004 02:46 PM
