apps problems
any thing besides that
I have had apps problems,meaning it unlocked the converter when i was at 40-45 mph and sometimes would kick out of overdrive at 60 + ?. it as very consistently inconsistent. mine didn't have the air bag lights etc. What codes do you have. if it is an apps problem it will have a code. Do you know how to see if there is a code in the system?
Well Sense I First Posted This I Checked My Codes And Kown Of Them Had Anything To Do With The Lights That Were O And Know My Lights Have Went Out . So I Don't Know What The Problem Is Or If There Even Is One.
I just changed my apps and there was know code. The throttle was hunting of had dead spots, but cruise worked great. Figured it had to be the apps and it was.So know code doesn't mean there isn't something wrong. I don't know if I have this right or not but the ABS computer is seperate from the truck computer. If you have a ABS light you can try pulling the fuse for 30sec and reinstall to reset ABS computer. If the light is still comeing on then it soundes like you have a ABS problem. Search and you can find lots of info on here. In order to scan the ABS computer for codes you need a DRB 3 scan tool. ABS codes will not come up in the odometer window. And know the smarty can't scan this either
