Any one NOT like the solid steel trac bar conversion???
Old 01-08-2008, 01:42 PM
Fishin2Deep4U's Avatar
I have looked into the Thuren. I'm not sold as of yet. But that's just me, I'm not saying it's not a good product or anything.
I like the idea of the SolidSteel mounts and the way they distribute weight without welding.
Dave
Old 01-08-2008, 02:35 PM
Beast2B's Avatar
The Skyjacker relocation bracket required grinding and adding a bolt-on support, so this was an impressive piece to me. Don didn't build the kit for ease of install by a backyard mechanic (me!), it's built for abuse (IMHO).
Which lift kit do you have on your truck? How did they relocate the track bar in the first place?
Old 01-08-2008, 07:07 PM
afoulk's Avatar
I bought mine thru KLM too. They seemed to be a little bit cheaper than the other dealers, and My first one actually got lost by FedEx. I called KLM and they got back to me with what happened to it within 5 mins. and shipped another one to me next day air and didn't charge me for it. I was very happy with the service.
Old 01-08-2008, 07:09 PM
afoulk's Avatar
While I'm at it, does anyone with the SolidSteel adjustable track bar have a lot of play in the bushings? Mine has atleast an 1/8" of play, if not more in the bushings which seemed odd to me since they are polyurethane. I called SolidSteel about it, and they sent me another set of bushings to try, but I havn't gotten around to putting them in yet.
Old 01-09-2008, 08:39 AM
Joe Diesel's Avatar
I added a Thuren track bar & the DSS stiffened up my front end good no wonder
Old 01-09-2008, 08:44 PM
dieselman2300's Avatar
My Thuren will be here on Mon.
Old 01-10-2008, 10:04 AM
01RAMer's Avatar
Installing mine, I had a deal of a time inserting the bolts as they were very tight. The bushings in the bar had no play either, so I would say right now, without rechecking, that I have NO play in mine.
Old 01-10-2008, 11:24 PM
Lil Dog's Avatar
Originally Posted by cLAYH
Thought it was a bit pricey but I should never need another track bar so why not. I also did the steering box brace as well. It did a good job of cleaning up the bump steer I had when hitting a bump at speed but didn't do much for the play in the steering. I was hoping for a bigger improvement but I think my box might be worn.
If you are lifted you'll probably really enjoy it but for stock you might not see a huge difference.
I got mine at a local shop here in Alberta.
I've had mine on for a couple years now. No problems. I also did the DSS at the same time. For the steering play, try adjusting the preload on the steering box. I turned it in about 1/4 to 1/2 turn and it really tightened up the steering feel.
89dieselkong
02-12-2011 10:06 PM
Derek Roch
05-20-2010 11:54 AM
afoulk
09-06-2007 11:23 PM
just_crankin_it
13
06-01-2007 04:12 PM
6 Shaker
01-18-2006 06:00 PM
Quick Reply: Any one NOT like the solid steel trac bar conversion???
