AC Select
Old 06-08-2003 | 08:32 PM
winner172's Avatar
AC Select
My AC is stuck on floor.<br>If I switch to max AC or vent it still blows on my feet.<br>Has anyone else had this problem
Old 06-08-2003 | 11:33 PM
Stamey's Avatar
Re:AC Select
Since the vents are controlled by vaccum, and it defaults to defrost if there is a vacuum problem (no vacuum), I suspect the selector switch.<br><br>Chris
Old 06-09-2003 | 08:17 AM
Palmetto_kid's Avatar
Re:AC Select
i had the same problem. i changed out the vacuum actuator for my dash vents, and it worked fine. its right up under the dash near the brake pedal. there is another one down in front of the gear shifter(manual trans,).<br><br>take the vacuum hoses off of the actuator, and see if they are still pulling vacuum. if so, then you actuator is hosed. if you dont have vacuum at alll, you hose could be pinched, or you could have a bigger problem. i would check the actuators first. the actuators just move the vents when you turn the selector.
Common
16
05-06-2007 11:50 AM
the_fox_man4
10-24-2006 10:22 AM
4x4dually
32
10-03-2006 09:24 AM
Igor
11-04-2005 02:03 AM
NWDave
11-16-2002 10:40 PM
