AC question..
AC question..
I installed a new AC compressor yesterday and the clutch did not engage in the AC positions or heat positions. There is some kind of sensor or switch with wires going to it on one of the AC lines, I was wondering if it is a pressure switch that will prevent the compressor from kicking in if there is nothing in the system.. anybody know ?
likely you are low on freon, you can TEST your clutch by running the truck unplug the switch and jumper it, if the clutch engauges the clutch and wiring is fine, but likely your low on 134 or the switch is bad, best to have the pressures checked, over filling the system is worse than not enough.
was it empty when you asked? if it was I retract my previous statement to Duner, my apoligies, I re-read the first post and now notice(I missed it) that you replaced the COMPRESSOR, which would mean the system would have to be empty, you had it evacuated right? and after removing the AC compressor QUICKLY replaced the compressor, so that the system was not open to moisture( the Dryer will suck moisture out of the air, effectively ruining the dryer and causing ac issues later , ie freezing up/poor ac performance)
If you live in an area of high humidity I would consider changing the drier, if not then leave the vacuum pump on extra long and ensure the vacuum is 29-30 inches. This will boil out the moisture. Then close the gauges and make sure that the system holds the vacuum. It should NOT drop any, if it does you have a leak. A leak will show better with vacuum than with it charged.
mkeanglorldo56
11-04-2007 12:34 PM
Oval Racer
01-26-2007 02:57 PM
8mpg
05-08-2006 06:37 PM
