AC Condensation leak
Old 08-14-2003 | 08:41 PM
hlc's Avatar
hlc
I drove from Atlanta to Montgomery today (~2 1/2 hours) and when I got to Montgomery my passenger floorboard was SOAKED. Got under the truck to see if I could see a drain that maybe was clogged but couldn't find anything (not even a drain). Help! Thanks...
Old 08-14-2003 | 09:22 PM
bulthisl's Avatar
Re:AC Condensation leak
Look right behind the down pipe.
I just had the same prob.
I raised the carpet and put a beed of sylicone around where the drain goes through the firewall on the inside and the outside.
I normally don't like to rig things like this but to remove the heater box you have to drain the freon.
If this don't work I will
: Eddie : 8)
Old 08-16-2003 | 09:03 PM
Stamey's Avatar
It should be right behind the filter dryer.
The dryer is the black canister with the green connector on top. The pics are from a 99, but they should be the same.
Chris
Old 08-16-2003 | 09:36 PM
Mostwanted's Avatar
WHile on the subject, I sure do get a lot of condensation leaking on the groound. I know some is norm. , but I get a lot
Old 08-16-2003 | 09:52 PM
Stamey's Avatar
How humid is it in your area? I get a steady stream from mine, but it's humid as #$%#@ here (read sauna).
You could look at it as a good thing, that your AC is working very well. ;D
Chris
Old 08-16-2003 | 10:43 PM
Bearfoot2's Avatar
[quote author=Stamey link=board=5;threadid=18412;start=0#msg173412 date=1061088757]
You could look at it as a good thing, that your AC is working very well. ;D Chris[/quote]
Every time I've been in MO. (too many) the humidity has been at or near 100%. Last time I was in K.C. - summer of '02 - it was 107[sup]o[/sup] and 100% humidity. When I stopped for fuel it looked looked like a water faucet was turned on under my truck.
On the radio, every 5 minutes they were giving the temp, humidity, and heat index (I think it was 113[sup]o[/sup]) and telling the ill and elderly to please stay inside. Sure glad I don't live there. My cousin lives in K.C. and owns a heating and A/C shop. He loves it in the summer time.
Stan
Old 06-18-2006 | 08:48 AM
Ironstone's Avatar
Hey!
I dug up this post to see if this fix worked for you guys?
It was really humid yesterday and about 90* so I had the air on full. I had a steady stream of condensation runnin in to the passenger side floor board (luckily I have rubber and not carpet). Sounds like a water fountain runnin inside my dash. Might be a soggy summer
Old 06-18-2006 | 09:08 AM
Stamey's Avatar
Just fixed my 96 2 weeks ago. Driving to the Claremont diesel rally I found that every right curve I drove on gave me a water faucet on the right floorboard. When I got to the rally I found that the little hose was gone. I stuck a pocket screwdriver into the hole and wiggled it a little. Low and behold, Niagra Falls out the firewall, for about a minute.
No problem since.
Chris
24cummins
10-28-2003 09:48 PM
ghostrider747
10-08-2003 10:09 PM
97Dually
13
06-14-2003 12:21 PM
ekim440
01-02-2003 09:16 PM
Quick Reply: AC Condensation leak
