97 Ram 2500 Fuel Gauge stopped working, ABS and Brake Lights On
I purchased this truck last weekend and it runs great. The thing is, when I got in it this morning the fuel gauge was not working, the ABS, brake light, and low fuel indicator lights are on. When I first start it if I keep it idled high the ABS, brake, and low fuel indicator lights will stay off but the fuel gauge still stays on empty. This all started at the same time. Any ideas on what the problem might be or where to start looking????? Any help would be appreciated!!!!!!
First thing I'd suspect are the grounds. These trucks are notorious for have grounding problems. otherwise it might be in the PCM . The fuel guage though could be a problem on it's own. The sending unit is notorious for bad contacts. Can be tightened up, but about $50 for a new one. Loosen the bed bolts and just tip it up in the driver front corner to get to the tank unit. Or drop the tank, PITA.
A must have in your toolbox for electrical problems> http://www.genosgarage.com/products.asp?dept=241
Steamin 22
06-23-2014 11:16 AM
JamesOneill
06-02-2013 10:09 PM
tmccormick
01-29-2013 08:49 PM
The_Head
12-05-2008 03:20 PM
polaris800sp
11-13-2008 05:35 PM
