97' 2wd ball joints...threaded or pressed
Old 09-12-2006 | 09:54 PM
BobWatts's Avatar
Just picked up my new ball joints(Moog) and found that both the upper and lowers have to be pressed in. From what I have been reading I thought the uppers were threaded in and lowers were pressed in.
My truck is a 97' 2 wheel drive dually. Anyone else out there have any experience with the same truck?
And I should ask how easy it is to replace the ball joints with out removing the control arms from the truck? Thanks
Old 09-14-2006 | 03:28 PM
kd460's Avatar
Very easy if you pick up a ball joint press from harbor freight for $30 bucks. Well worth it. They can be use for u joints and other things so you will get your $$ worth.
Not difficult to do. Just follow the instructions in a Haynes, Chiltons, or factory manual. Press old one off, new ones on.
If I remember correctly, you will need a pickle fork also. KD
firebill1720
20
03-05-2010 09:23 AM
kevinO5
06-15-2009 09:54 PM
b.lee
02-26-2008 05:57 PM
bucknasty
08-15-2007 11:23 PM
Quick Reply: 97' 2wd ball joints...threaded or pressed
