97' 2500...Is it worth it??
I just went and looked at a 97' 2500 diesel. standard cab. The truck needs work. Needs an exhaust, will need 4 tires, feels like a loose ball joint, the ABS and brake light are on on the dash. The battery is held in by bungee cords.. No rust anywhere wich is a good thing. It has 85,000 miles. It puffed a little blue smoke on cold startup but cleared up in a couple minutes. the truck has been sitting. It ran pretty good and smooth. Whats it worth about? I could get it for about 4500$. Thanks!!
overhead would be pulling the valve cover and setting the valves
I can do all the work myself. It's going to be a plow truck. I need some more confidence votes.. C'mon people should I jump on it?? These trucks are going for 10,000 plus with over 200,000 miles.......
What you described...Its worth it.I would jump on it.Where I live,we don't see dodge diesel trucks going for that price.That truck would sell for at least double....The milage is also very very low....I would take a chance...
If the body and interior are good. Sounds like a good deal to me! The 85k miles is enough to make the deal imo. You say it "needs an exhaust" like it's a bad thing...
are you joking thats the cheapest priced truck i've ever heard of i would buy it asap the brake is most likely on becuase it need brake fluid check that first. the abs could be a $400 part but even if it is your still only into this truck for 4900 and then tires are 600-alot depending on size of course and the balljoints aren't that much.
rcotton
06-02-2007 09:54 AM
pwrtripls1
12-24-2005 05:13 PM
