96 3500 ground problem
Need some help. My 96 3500 seems to have a common ground issue. The tach, CC, AC, and alternator all go dead at the same time. Then after a few hours they all come back on at the same time. I thought it was ECM, swapped it out and still no go. I have traced every wiring harness looking for bad connections or worn spots. Nothing. If i ground the alternator and hook up a hot wire it will work but it charges full blast with no regulator on it. I do a lot of night driving so I need it to charge a little. Every once in a while everything will come on and work fine then the next time i park for a few hours nothing works again. Any ideas. Twenty years and 333K miles and this is the first time it has me stumped.
Guarantee you it is your Engine Speed sensor circuit.
Just for grins, on the front of your engine,m somewhere around the water pump area is a connector that hooks the speed sensor to the harness.
Take it apart and clean that connection with contact cleaner.
Mine got oil soaked and would intermittently pull the same stunt.
Anyway, without the Tach signal your CC,AC, Charging, and O/D ( auto trucks) go away because the PCM doesn't know the truck is running.
Thanks Patdaly. I'll give that a try this evening. 'll let you know how it turns out. I took that off because it looks bad but it cleaned up and i put it back on. If the speed sensor is out then that could be the whole thing. I'll give it a try. Thanks
Yep that did it. I put the new sensor on and set the gap and now everything works like a new one. Thanks for the tip. I was about to go crazy checking wires and testing things. Should be good for another 300K.
TankerIP
02-26-2011 09:17 PM
JVDodge
0
01-05-2008 08:19 AM
