60-70 mph vibration and growl
I've got a vibation at 60-70mph its not really a growl but defiantly doesn't sound right. I have an ATS tranny with under 10000km on it. I replaced the rear u-joint along with the tranny, the front u-joints, wheel bearing, other u-joints have little to no play, I also replaced the rear pinion bearing and seal tonight, any other thought of what this might be
I had my driveshaft balanced when I got my ATS rebuild. That balancing really smoothed things out above 60. But if the vibration is a recent thing you might check out the center support bearing that supports the driveshaft.
I had a vibration at the same speeds a while back. After replacing all steering, ball joints, drive shaft, shocks it ended up being my track bar was a little loose. Torqued that thing down good on both ends and that fixed it.
i took a pry bar to my u-joints and all looks good, i pulled the front drive shaft off last night and still have the vibration. i dont have a steady bearing either... this is starting to burn me out. I dont want to have to just start throwing parts at it either
The u-joints can be bad w/o being loose.
Look for a rusty dust around the seals.....Pull the rear retainers and try to rotate the u-joint by hand. It is a free check to be sure.
I just replaced my U-Joints while I did ball joints, etc. Hadn't noticed anything out of the ordinary really, just a bit of a vibration, nothing visibly wrong though.
Put new Spicer cold forged joints in, and when I took it apart, one of the originals had turned to powder.
One thing I would suggest is, get original SPICER joints, there is a reason they are 45 bucks each versus the typical autoparts store 20 dollar joint.
Everyone one of us was incorrect on this, thanks for all the information, I just did most of the u-joints on the truck... The final thing that got rid of my vibration, was I had balancing beads in my tires and the shop that did it never took the old weights off. I'm thinking one must have come off and threw a vibration, now we're all good thanks everyone again, now to find out why I blew a tranny line on my final vibration test drive
treemonkey
06-17-2009 02:06 AM
roughstock
06-18-2006 12:15 PM
Mark Hodowanec
11-13-2004 11:02 PM
Mark Hodowanec
11-10-2004 06:41 PM
Commatoze
11-21-2003 07:55 PM
