3m adhesive tape removal
I recently lost one of my bed rail caps so to install 2 new ones i need to remove that adhesive tape- i have heard of eraser wheels but the ones i find on the web require a special type of power tool to use them
what have you guys used?
thank you,
Patrick
thank you,
Patrick
lilbro beat me to it. Dang it!!!! You can also try diesel or gasoline, just don't let it set to long. Test what ever you use on the underside of your bed rail to see if it will affect the paint.
tar and adhesive remover will take it off with out hurting the paint, just soak a rag in it and let it sit on the tape for a minute or two then use a plastic razor blade to remove and wipe of residual adhesive.
tape removal
good Luck,
I know this sounds strange, but try cleaning it off with vegetable oil. I've used it on some stubborn adhesive before and it worked better than anything else I had tried. Admittedly, I've never used it on 3M.
03qclb5spd
03-14-2008 07:50 PM
FireNhole
12-30-2002 11:09 AM
