285 or 265 tires ?
Old 03-02-2007, 06:35 AM
pete97's Avatar
285 or 265 tires ?
I need to replace my tires soon and was wondering should I go with 285/75/16's or 265/75/16's ? Thanks Pete
Old 03-02-2007, 06:50 AM
mysterystench's Avatar
285's will look better and fill the wheel wells a lot nicer than the 265s
Old 03-02-2007, 07:57 AM
pete97's Avatar
Thanks, I'll go with 285's then. Mysterystench, do you have 285's on your truck?
Old 03-02-2007, 08:08 AM
dzlfarmboy's Avatar
I like my 285's i think their the best all around tire for these trucks at stock height
Old 03-02-2007, 10:14 AM
Dave88LX's Avatar
285's on my truck too.
Old 03-02-2007, 10:33 AM
pete97's Avatar
Thanks for the info so far. Any problems with them fitting?
Old 03-02-2007, 10:45 AM
Dave88LX's Avatar
None at all.
Old 03-02-2007, 10:55 AM
Ridiculous's Avatar
i've got them too. they look nice but beware of the psi. don't inflate them to full psi or they will wear in the middle more than the outsides.
Old 03-02-2007, 02:22 PM
clarson80's Avatar
I have 285's and like them but with my next set I think I might try 255/85's...a little more than an inch narrower and just a little taller. There are very few a/t tires in that size, mostly mud terrains, but there are some.
Aren't taller thinner tires supposed to be better in snow (not REALLY deep obviously) and ice? Plus they would be lighter which MAY help with mileage.
Just my $.02
Old 03-02-2007, 03:03 PM
pete97's Avatar
I'll have to take a look at it. Lots of choices. Pete
Old 03-04-2007, 12:50 PM
powersmoke's Avatar
Just my $.02
Yes you will definatly get better traction in the snow and ice. Also being narrower, it should help a little with mileage.
Old 03-24-2007, 10:12 PM
mcinfantry's Avatar
anyone running these sizes on a 2wd?
Old 03-24-2007, 11:50 PM
Forrest Nearing's Avatar
yes, you can run them on a stock height 2wd if you use stock rims, and you'll get a little rubbing on the inner fender sometimes
285's are a great tire on a 4x4. I wanted 255/85, but finding a decent E rated version put me in the $250/tire range! so I went w/ the 285 BFG AT's at $170/tire. glad I did, they look great and wear great
Old 03-25-2007, 12:07 AM
kevellis32's Avatar
If you are looking for an even better look, go get a leveling kit and get some 315's, take a look at my profile pictures I have them on my truck and I get quite a few complements and you sit up just abit higher that makes your truck alil more unique from what I have seen. Just my 2 cents though...also, if you go with 315's, make sure you get your spedo re calibrated. I got pulled over when I thought I was doin 75, turned out I was doing over 85
Old 03-25-2007, 02:58 AM
I had D rated 315's on my truck and I hated the way they rode/drove... I would consider trying an E rated 315, but the prices on them was just too high to justify. the truck drives/stops/steers so much better w/ the 285's than it did w/ the 315's
jmo
Quick Reply: 285 or 265 tires ?
