1998.5 2500 24 V Would like to raise the rear about 1" I have searched but what is my
Hi, I just picked my son up a 1998 2500 24 V Cummins, It has a level it appears ( and was told ) but it sits high about 1' over the rear. I am not looking to really keep raising the truck just want it leveled.
Add A Leaf? If so which do you recommend and any how to links?
1' Block added if so any links?
Do I replace the stock Block? if so what do I replace it with?
Air Bags?
Truck will pull different trailers from time to time and carry quads/Snowmobiles around.
Thank you and yes I have searched a ton.
Air Bags?
Taller tires on the rear.
Seriously, if you are going to haul or tow, airbags are worth it....
Or depending on where you are, get the rear springs re-arced....
Kurt
Kurt
My experience with fittings and road salts has been go with the plastic push-lock fittings over the all brass one's. Both sides corroded and leaked down my bags after about two years. The plastic swivel one's are still holding after putting them in in 2015...
Just a FYI if you go with bags and are in snow country...
Kurt
Kurt
Joey.G (11-23-2023)
So I was able to locate the owner who did the work to the truck, He said he used Thuren 2.5 inch springs on the truck and had them powder coated to color match the truck. I did measure and the truck actually appears to measure level, I don't think it actually is nose high but it sure does look it. I'll probably go with air bags any way for towing purposes.
mstep3
05-20-2009 11:32 PM
TNUTZ
51
04-04-2008 11:37 AM
