Would this work as a fuel pressure gauge?
yes it will work but that is very expensive by the time you add postage and buy the banjo bolt snubber and copper oil pressure gauge kit you are going to have a lot of money in it , i would order the taped banjo bolt and $17 gauge from geno's garage from local parts store get a 18"grease gun hose and a oil pressure gauge installation kit change the bolt out on the pump grease gun hose next copper tube next and gage all of the fittings are in the kit the gauge has a built in snubber if the copper line makes noise contact me and i will show you how to build a snubber for about $2 you can put it on the hose kit connection
He has a 99. He can simply take out one of the plugs on top of the filter housing and screw the sensor in. Run the wires thru the dash and mount it. It'll take about 15 minutes. 16 if you slug a cold one in the process.
I've had the same dilema, dont want to spend alot of $$$, but want a good guage... I spent most of last night searching the web for fuelpressure guages.... and what I learned is.... There are a ton of cheap guages, but seemingly always a catch. THE BIGGEST that I saw was most pods for guage mounting are 2", and a LOT of guages that are 1 1/2".
I then pulled out a geno's catalog, and found out that when I order a westach Fuel pressure guage, I get thrown in for free,
the wiring harness
a mounting plate for the guage inside
a mounting bracket for the sending unit
and a free window decal that says "cummins turbo diesel"
I'll be paying for the guage $74.95 and a Fuel Pressure line for $19.00
and shipping...which you'd pay anywhere you ordered something.
How can you go wrong with that?
-Tim
the wiring harness
-Tim
Heck with all of that. Our fuel is an oil, get an electric oil pressure gauge. Got mine on ebay for $20 including shipping came with the sender and gauge and all the wiring needed. Works perfectly and you can screw it right into the port on the fuel filter lid.
Just what I did and it works great for me.
Dave
Dave
dodgeguy71
17
01-19-2012 01:52 AM
mysterystench
06-17-2009 04:36 PM
HappyGA
02-04-2005 10:10 PM
Patriot_RAM
10-08-2004 07:10 PM
