Would like a 2nd opinion on engine rebuild
I finally got another block on its way here. So i have to take the internals of my 53 block and swap into the new block. What bearings should i use. Cummins bearings or aftermarket bearings? I am replacing the crank and connecting rod bearings
OEM parts (Cummins) are gonna wear you out. Jist start doing search on internett. You will find deals. Pistons are made by Malhe (sic) You might try some parts stores also. they can generally order.
The old saying you get what you pay for, we know the cummins parts can go a longtime, what is to say the auto store parts are the same specs. I know that getting parts to precise specs can cost alot more money, which could be the difference in cost. JMO
mwbates
13
09-25-2011 10:21 AM
jcw74801
12-10-2007 11:56 AM
C&C Milo
15
04-16-2007 10:08 AM
Turbinator
16
08-31-2006 01:49 AM
