Wieght rating for factory 16x8 aluminum wheels and drum questions
I am not been able to find a weight rating for the factory 16x8 aluminum wheels.
Does someone know what it would be?
When Dodge offered the aluminum wheels as an option, in 2000 I believe, they also changed the drum shape.
Can these later drums be retrofitted on early 2nd gens (94-99)?
I would assume they will hold up to the max weight rating of an E rated tire of stock size.
Yes, the newer rims will work on the older trucks if the drums are ground a down a bit.
I know they will fit the older drums with grinding but, I am also wondering if the later drums (00-early 01) can be fitted on the older axles (94-99) then no grinding would be required.
Just wondering.
Just wondering.
One would think but I have seen rims with the weight rating on them that were not rated as high as the mounted tire. This was a PU rim but can't recall what it was off and don't know if the tire was the recommended one or not.
GlennRMK
07-17-2005 09:39 PM
CTD_Neil
03-11-2005 01:09 PM
thecatsfan
02-27-2004 02:08 AM
thecatsfan
12-30-2003 11:44 PM
