White Smoke, Power Loss, Diagnostics Code?.. Need Help
Old 08-28-2007 | 06:58 PM
billaweed's Avatar
I'm fairly new to diesels so I have to ask some opinions on this one. First of all, when I start my truck up I get some white smoke comingout for a few minutes. Sometimes alot of smoke and sometimes not much.
second, when I'm on the freeway my truck will slow down losing speed and power, but my RPM's will stay the same. and this only happens when my speed is between 35-60 mph. the only way I can get back to speed is by slamming my pedal to the floor, and even then it boggs out before accelorating.
I had a diagnostics test ran and the code read "Injection pump Timing Fault". Now I'm not sure what that means exactly, but can the transmission or a chip somewhere be causing this problems or does it mean my pump is going out? It seems to me that if its a "Timed" pump that it could be re-timed, but then again I am to to diesels.
please help this noob out.. thanks
Brandon
Old 08-28-2007 | 07:08 PM
phox_mulder's Avatar
What year truck?
phox
Old 08-28-2007 | 07:17 PM
billaweed's Avatar
its a 02 2500
Old 08-28-2007 | 07:24 PM
A dying lift pump will cause that code.
Most will say it's the code of death for the injection pump, but not always.
Find out the health of the lift pump by getting a fuel pressure guage on there, and if it is indeed dying or dead, replace it ASAP, as a dying or dead lift pump will kill an injection pump pretty quick.
phox
Old 08-28-2007 | 07:28 PM
billaweed's Avatar
ok.. where is the lift pump located? in the tank?
Old 08-28-2007 | 08:06 PM
Stock location is on the side of the engine, just below and behind the filter.
If the pump has been replaced by the Dealership within the past year, year 1/2, it will be in the tank and the one on the engine will be MIA.
phox
Old 08-28-2007 | 09:18 PM
billaweed's Avatar
really? I was told that all the pumps were in the gas tank and changed to external in 03.. How will I tell if the lift pump has gone out? should I just take it to a dealer?
thanks
Old 08-28-2007 | 09:32 PM
blackdiesel's Avatar
Registered
You could still be under warrenty. You have to check fuel pressure and or volumn to test the lift pump. 90% or better chance both pumps are toast. IMO
Depends on your mileage.
If you are under 100K, then you should still be under warranty.
(or 136K going "by the book")
Search out the recent-ish discussion on when the Cummins warranty kicks in for the upcoming Dealer fight.
If you are well outside that range, it'd be much cheaper to either do it yourself or find a local shop that knows Diesels.
It used to be if you were showing that code, the Dealership replaced the lift pump and VP44 unless you had obvious modifications, I.E. performance box.
Expect on paying around $200+ for a lift pump R&R, $1200+ for a VP44 R&R if it ends up being the injection pump.
phox
Old 08-28-2007 | 09:45 PM
billaweed's Avatar
if it is just the lift pump, what would be a good one to replace it with?
Old 08-28-2007 | 09:55 PM
billaweed's Avatar
oh.. and right now I have 150000 plus. I've put 14,000 on it since I started noticing the problem. stupid me... If anyone has had to have an injection pump replaced at a garage can I get some price quotes? thank
brandon
Attached Thumbnails White Smoke, Power Loss, Diagnostics Code?.. Need Help-truck.jpg
Old 08-28-2007 | 10:02 PM
Registered
cheapest I've heard of is around 1800, the hightest 3300, bouth from dealers.
Old 08-28-2007 | 10:05 PM
emoryemt-i's Avatar
Thumbs up
I HAD TO REPLACE THE ONE ON MY 2000 AT 113000 MILES. IT IS FAIRLY SIMPLE TO DO AND YOU CAN DO IT YOURSELF IF YOU HAVE A LITTLE TIME AND MAYBE A GOOD FRIEND TO HELP YOU. DO A SEARCH ON VP-44 REPLACEMENT AND LP OPTIONS. A NEW VP-44 WHICH IS YOUR INJECTION PUMP WILL COST YOU 1046DOLLARS AND I JUST BOUGHT THE AFTERMARKET WALBRO SETUP OFF THIS WEBSITE SEE SHOP DTR AT TO OF THE PAGE. ALSO YOU NEED TO GO AHEAD AND PUT SOME GUAGES ON YOUR TRUCK OR AT LEAST A LOW PRESSURE LIGHT. I AM SORRY YOU HAVE HAD THIS PROBLEM I WAS VERY MAD WHEN IT HAPPENED TO ME BUT THINGS HAPPEN AND THE GUYS HERE HELPED ME THRU IT AS THEY WILL YOU.
Old 08-28-2007 | 10:12 PM
billaweed's Avatar
yeah.. I'm pretty upset cause I actually bought this at 130,000 miles. It's my first diesel and it ran fricken sweet when I bought it. I drove one for work and loved it so I decided to buy one. Now I kinda regret it because i didnt get a warranty with it. So while im paying this off i gotta replace some expensice parts as well. SUX...
anymore help on parts etc.. is greatly appreciated..
thanks guys
Old 08-28-2007 | 10:33 PM
emoryemt-i's Avatar
like i said i had to do it and i am still paying for my truck. midwest fuel injection is the cheapest place i found to get the vp and depending on where you live you might be able to get one of the other 24v owning members on here to help you get yours running.
Quick Reply: White Smoke, Power Loss, Diagnostics Code?.. Need Help
