Where to buy a vp44 - recommendations?
Old 10-31-2008 | 02:29 PM
bert01ctd's Avatar
I have gotten the dreaded code 0216 and I need some advice on where to buy a rebuilt vp44. The dealer wants $3000 to replace it. I have decided to do it myself with the help of a buddy who is a mechanic. I need to know who sells these with all the necessary hardware at a good price? I have read that some do not come with all the hardware such as o-rings, etc. and to not buy the ones made in CZ. So, I need some help. I have read that MWFI and Pensacola Diesel are good. Any suggestions? Thanks
Old 10-31-2008 | 03:10 PM
dkenny's Avatar
I won't suggest your Vp44 isnt gone...
but have you changed the fuel filter?
have you install a fuel pressure gauge? is it reading over 5psi?
I only ask because when I bought my truck is had p0234, p0236, p0216..I changed the filter and installed a pressure gauge..so far no more codes.
sure I suspect that I'll be replacing the vp44 in the future but not at the moment.
-dkenny
Old 10-31-2008 | 03:40 PM
j-fox's Avatar
Do a search on Blue Chip.
He has a top reputation aand I have one of his VP'S. It has been great for 80,000 miles.
Old 10-31-2008 | 05:29 PM
bert01ctd's Avatar
Yes, the fuel filter is good and my edge monitor says fuel pressure ranges 11-14 and 10 wot. I do get the dead pedal every once in awhile but that is the apps. I just want to make sure I get everything to replace the injection pump.
Old 10-31-2008 | 06:24 PM
Kenworth's Avatar
Bought mine through Diesel Distributors USA. Also got a Raptor 100 lift pump. Everything you need is included, no core charge unless old pump isn't returned within a month. Very easy to replace. Took me under 2 hours for the pump and another 1.5 hours for the Raptor.
Old 10-31-2008 | 07:55 PM
johnh's Avatar
since you're close to industrial injection in slc ut they would be a good choice
https://stores.myregisteredsite.com/...VP44+Fuel+Pump
Old 10-31-2008 | 09:26 PM
blacklab467's Avatar
vp-44
I got mine from clicking on the ad at the home page ($1030.00). I watched diesel-dan's videos on you tube and did it myself. I'm not a mechanic but it was pretty easy, Dan tells you what tools to get and everything. I also did the lift pump. Got that from BD Diesel in Vancouver. It was about $450 CDN. Thats about $400 USD, also real easy to change with instructions included. The hardest thing about changing the VP-44 was the lines. Get a 19mm stubby wrench, I used a standard length. The VP took about 4 hours and I was working slow, the pump took about 2 hours. Good Luck.
Old 11-01-2008 | 01:16 PM
azctd2500's Avatar
I just replaced mine last month. Got it from www.mwfi.com for $1250 with new lift pump. Took about 3 hours total to swap out.
Old 11-01-2008 | 03:23 PM
rebal's Avatar
I have bought a few from blue chip never a glitch and super to deal with
Old 11-06-2008 | 08:58 PM
snow7899's Avatar
I love my Blue chip. Very easy to deal with.
Old 11-06-2008 | 09:02 PM
Tim Adams's Avatar
i woudnt recommend that you do the install yourself unless you are very familiar with those motors
Old 11-07-2008 | 12:02 AM
PaulDaisy's Avatar
Just take your time, don't hurry and use a light and a mirror to make sure the key is lined up and not jammed before torquing the nut on the pump shaft. I think that replacing the VP is a perfect way to get familiar with these trucks: you get to touch all the vital parts and are not afraid of it anymore.
I bought mine from Pensacola Diesel and had no problems with it for nearly two years now. I looked on E-bay for the best price and called the supplier to inquire if they are an authorized Bosch facility, and they told me yes and that in fact sometimes they re-sell VP44s from II when they run short of their own.
Old 11-09-2008 | 08:36 AM
rigsy340's Avatar
my next pump will be blue chip, also dead pedal is the pump, not the apps.
Old 11-09-2008 | 09:18 AM
Big Deezul's Avatar
industrial injection or blue chip
Old 11-09-2008 | 01:17 PM
Brokenarrow's Avatar
Actualy dead pedal can be the apps to! It was on mine! What are you looking for? A hot rod pump or just a stock replacement? Scheid or industrial injection has got my vote!
