Whats wrong with my truck
I just filled up with diesel and only got 11.74mpg. Now I pulled our camper to our favorite campground last weekend and I normally get just over 14mpg towing our 6-7000lb TT to the same place. I have been noticing more black smoke lately but not much. A fuel gauge is going in next weekend, were camping again, same place, this weekend but just curions on the over 2 mpg loss all the sudden.
Thanks.
Bill
Thanks.
Bill
Originally posted by Lil Dog
Hook up that gauge for fuel pressure pronto... I suspect your LP has left his world for a higher place...
Any positive ideas like a dirty IAT sensor, please please please
How can I test the fuel pressure without a gauge ASAP. Shrader (sp) valve will a digital tire gauge work in a pinch, is it even close to the same size? Sorry I'm a noob
Ya know I wish I knew for sure.. Sorry, I hope someone on the 24V train can help with this..
You may try posting this again over in the 24V forum or PM the moderator to move it over for better exposure. Or try a search in the 24V area...
Well strictly on a pressure front... If the lift pump pressure is lower, then the injector pump has to spend more time to reach injector pop-off pressure. With this delay you get firstly late timing and secondly you need to add more fuel in the process due to the change in timing to achieve the same power output. The VP 44 does electronically control timing, but if your pressures are low, it doesn't know that and will still try to achieve the same injection event timing. So it will signal the pump to begin the injection to cylinder 1 at the proper time, just the delay in pressure delivery, delays the actual injector timing..
Well for what it's worth, we went camping with our 6-7000 TT in the mtns and no problems what so ever with power. Like I said before fuel pressure gauge is going in this weekend with an oil change, fuel filter and for good measure cleaning the IAT sensor.
Just for the record what are the signs of a LP going out besides the dead pedal. Will you hear the turbo spool or with the lack of fuel not so much. I know pressure is you best bet but...
Bill.
Bill.
I use a fuel pressure test gauge from most chain type auto parts stores then modified it to run the gauge inside the truck. It'll also check the fuel pressure on my '97 & '92 Olds Bravadas (w/correct gauge) and the R12 freon pressure on my '86 Cutlass & '92 Bravada. If you happen to have an R12 install kit w/guage, it'll work on the Schrader Valve on your VP for checking your lift pump pressure.
TTT
92'1stGen
33
10-03-2008 10:48 PM
C Minus
22
04-15-2008 02:31 PM
BigBadMegaCab
10-01-2007 11:09 AM
silverram323
10-20-2003 01:04 PM
