whats the proper way to change brake fluid?
Old 01-21-2007 | 07:42 PM
dieselfan's Avatar
anybody got any tips or special tools that they use. whats the best way to change it? what type of fluid and brand?
thanks, brian
Old 01-22-2007 | 05:56 AM
Marine's Avatar
I have a good article on the fluid, and am searching my database now. You can flush it the normal way with 2 people- 1 pumps, one opens the banjo on the brake itself. Just don't run out of fluid. Also, they say you should start at the one furthest away for the Master Cylinder, but I think that is a bunch of bull.
You can also use the Speed Bleeder (search it) and it is a slick setup.
Search my posts on here, and I'm sure you will find the Brake fluid post.
Old 01-22-2007 | 06:29 AM
dieselfan's Avatar
thanks mike, will do when i get home.
Old 01-22-2007 | 08:34 AM
Marine's Avatar
Found it-
https://www.dieseltruckresource.com/...33#post1313133
It's a good thread...I brought it back to life.
Old 01-22-2007 | 11:16 AM
mini14's Avatar
get yerself a mighty vac and itill go much easier
Old 01-22-2007 | 12:51 PM
infidel's Avatar
If you use the pump the pedal method don't push the pedal down further than it went in normal operation. What happens is if you push further the master will travel into an area that hasn't been used and kept free of rust, it will likely tear up the seals.
Good way to do it is to put a piece of wood behind the brake pedal to limit how far the person pumping can push the pedal down.
Old 01-22-2007 | 05:51 PM
dieselfan's Avatar
at Harbor Freight, they have some type of brake bleeding system with a hand pump. will this do?
Old 01-23-2007 | 08:44 AM
mini14's Avatar
hand pump it itll take about 30min to bleed whole truck by yerself, and it assures no backflow of crude into the very expensive abs controller.
Old 01-23-2007 | 06:26 PM
dieselfan's Avatar
so your saying yes? its about $20.
CACalomino
09-30-2011 08:25 AM
wvfarmboy54
04-25-2010 10:04 PM
freierj
15
01-02-2009 12:00 PM
smokeum99ta
02-19-2007 11:11 AM
dieselfan
11-11-2006 06:44 PM
Quick Reply: whats the proper way to change brake fluid?
