Whats the diff. in HO and SO?
Old 10-12-2003 | 04:52 PM
peanut's Avatar
does anyone know what the significant differences are? Is the HO just equipped with a factory chip to increase fueling, or is there a harware difference?
i was just wonderin since i know nuthin bout them.
thanks a lot
Old 10-12-2003 | 05:12 PM
DODGE4X4's Avatar
Re:Whats the diff. in HO and SO?
The HO's injector pump is cranked up higher than the SO. The engine is the same in both just one of them comes with more HP and Torque. You can put a chip in a SO and you will be close or higher than a HO. That is my understanding of the 2.
Old 10-12-2003 | 06:21 PM
KatDiesel's Avatar
Since you have a 2000 I assume your talking about the 01 and 02 trucks?
On the HO engine the ECM is different, injection pump is different, the injectors are smaller, the compression ratio is higher, the factory wastegate is set to a allow a bit more boost, valve seat inserts for added durability.
Old 10-12-2003 | 06:59 PM
DODGE4X4's Avatar
Ok well I guess I didn't realy know the diff. :-[
Old 10-12-2003 | 09:09 PM
KATOOM's Avatar
Look on dodgeram.org. I think it told in detail there what the differences are.
Old 10-13-2003 | 10:26 AM
Rattletrap1's Avatar
upgraded pistons I believe too. My guess is it was the upgraded guts to prepare the motor for the '03 HO performance.
Strictly from a performance note...the compression is higher, the boost is higher and the fuel is decreased from an SO for a grand total of 10 horsies.
Old 04-17-2006 | 03:40 AM
ncmech's Avatar
Driving easily along the freeway I get 20 to 22 mpg too with the HO.
Checkmate
10-23-2006 04:33 PM
danimal 95
10-10-2006 11:43 PM
ocsurf16
10-04-2006 11:19 PM
mr T
04-17-2005 10:10 AM
j
09-26-2003 12:03 PM
