whats the deal with my truck being loud
i know that it was like what 2001 or 2002 when the ctd became not as noisy but what was it that they did? can i do it to my 99? was it somthing with the vp44 or something with the fuel system or what? just was in my buddys duramax and i kinda liked it.
there is no fuel rail on my 01? how does the fuel get to the cylinders?
im always learning...and still have alot to learn...
fuel goes from the VP44 where its pressurized through individual hard lines to each cyl, through a set of injectors and into the combustion chamber.
think of the vp like the distributor on a gasser. but instead of introducing electricity to the equation, it adds fuel. and just like the distributor, it has a certain "firing" order it goes through as the parts spin around inside.
the common rail engines have a injection pump that basically just pressureizes the fuel to very high levels and sends it to the "common rail" which is basically like the fuel rail on a gasser. Then there are individual lines going from the rail to each injector in the head. Theres always fuel being supplied to the injectors. Unlike the 24v which use mechanical injectors, the common rail's use electronic ones. each injector has an electronic solenoid that opens up and lets fuel into the injector when the computer module tells it to. The common rail engines are so quiet because since they use electronic injectors, they can actually inject or "pulse" fuel into the cyl. more that once per cycle. This helps quiet them down and helps lower emissions
Tyler_02
08-23-2011 12:19 AM
mytrucksaslug
14
11-02-2007 10:09 AM
Justwannabeme
06-05-2006 08:40 PM
