what size fuel lines
Im replacing my LP and right now I have the standard 3/8 line from the tank, then converts to 1/2. It was that way because there used to be a Holley blue in the middle. But the truck is now back to stock. if I replace the 1/2 and go back to 3/8 is that OK. Or' maybe the new Lp will work easier with the bigger lines.. what do you think.
Stix
Stix
Hey is it posible that the original LP location can cause the fuel line to colapse (correct spelling?) since its such a long run to the tank and starve the pump causing the failures???
big builder
12-07-2007 10:05 PM
Parvenu
10-18-2003 03:10 PM
