What Oil/Filter Do You Use?
Good Evening!
Just curious to see what everyone else here uses. Engine lubrication is a BIG interest of mine (not to brag, but I know a thing or two...), and while I'm no CLS, I did stay at a Holiday Inn last night!
Oil: Pennzoil Long-Life 15w-40
Filter: Fleetguard LF3894
OCI: 7,500 miles
OCI: 7,500 miles
Phillips 66 15W-40 HD -or- Exxon 15W-40 HD and Mopar Filter. I just found a spot to get Fleetguard Filters... Also I change every 6,000 miles on the 2002 on the 1996 I change 3,000 miles...
I use Rotella T 15w40 and a Fleetguard LF3894, change oil and filter every 6000 miles, I use a Fleetguard fuel filter and change it every other oil change.
As in Jelly from BITOG? I'm currently running Delvac 1300 with a Donaldson ELF filter, which I will drain in December after a year and around 7k. Found 3 gallons of your lube of choice for $3.98 each when a local auto parts chain went under, so that'll go in for next year. I'll probably go back to a regular Donaldson at that point. As far as oil in a Cummins goes, if it's CI-4 from somebody I've heard of, it's good enough for me.
