What is this?
What is this?
I was under my truck the other day, and I followed the tranny cooler lines from the trans. I assumed they went to the cooler mounted up front, but first they detour to this cylinder shaped tank mounted on the driver's side of the block, then they go to the cooler.
What is this thing and why is it there? I assume it is some kind of heat exchanger, but don't really know.
Anyone out there wanna help me out?
phox
Isn't that what the cooler out front is for? Why have 2? ...And this one looks like it's plumbed into the engine oil or engine coolant system as well, like a fluid to fluid exchanger?
BTW: No cracks here, my block is a "56" IIRC...
It is a fluid to fluid heat exchanger. It warms your trans fluid to the temp of the coolant. The fluid to air cooler is up front and it is to cool your fluid.
I know...it doesn't really make sense. Lol.
It's an ATF to coolant heat exchanger. It helps you in several ways. While pulling it transfers heat from the ATF to the coolant and since the ATF woudn't have the desired temperature after the device it goes to the cooler in the front. (That would need to be much bigger without hte heat exchanger and would keep the tranny temp below the desired level under low loads and cooler ambient temps)
While the engine is still cold you can use it to heat up the engine much faster by putting the truck into drive and high idling for some minutes (Necessarily the parking brake must work and if it fails the truck must not endanger anybody.- like while parking with the bumper to a wall if you are not in the truck) -
Because with this maethod you place some load on the engine and the heat generated in the tranny is transferred to the coolant too and helps to warm the engine quicker.
HTH
AlpineRAM
HTH
AlpineRAM
