VP44 rebuilding
Old 12-22-2007 | 07:22 PM
  #31
projectRam's Avatar
pump rebuild
i was wondering if you had any problems with the electronics as you stated they were almost 400. did you change them out to? rick
Old 12-22-2007 | 09:56 PM
  #32
jasonlee08's Avatar
in order to change the psg (electronics on the top of the pump) you pretty much hafta rebuild. and you definately hafta recalibrate it
Old 12-26-2007 | 11:58 PM
  #33
jcarew's Avatar
Talking VP44 rebuilding
Congratulations on your success with repairing your VP44 I know you are aware you saved yourself a large pile of money. Doing it in spite of all the naysayers was a good move. You must be an advocate of the old saying CAN,T NEVER DID NOTHING. congrats again JCarew
Old 12-27-2007 | 09:10 AM
  #34
high bid's Avatar
Originally Posted by my3sonsracing
It finally died --- The elctronics went bad and it finally quit working.
I got $20k miles out of it so it was worth the time an effort in my opinion. I got a rebuilt from the diesel store for $1046 and it runs great again.
Mike
Well, I would say all is not lost. Your post of the rebuild will shed new light for all those w/the VP44. If you rebuilt the entire VP44, seals and sensors couldn't one take it to an authorized bosch shop w/the bench test to recalibrate it?
The reason I ask is, I can get any bosch parts from my uncle, just have to have the part #. He could then run/test the pump after rebuild....maybe not for free but it's not going to be $1k. Just thoughts if/when the code strikes again.
Old 12-27-2007 | 10:15 AM
  #35
jasonlee08's Avatar
it is quite possible to find someone to calibrate it. they hafta have the bosch 815 stand with the vp44 kit. it takes anywhere between 90-120 minutes just for calibration. they also hafta dPhi 1 it which could take upto 60 mins. the dPhi 1 is the measurements that are required for the angle of rotation after you have put the pump back together. especially if you disconnected the AOR sensor (soldered to the psg) off of the shaft.
Old 12-27-2007 | 12:20 PM
  #36
12valve's Avatar
How much is a shot vp44 worth?
Would i get $500 ea for shipping a few old pumps to the bosch rebuilder people?
reason im asking is cause I bought a couple of brand new cheap vp44 pumps, for 600 bucks each and no core charge. (from a closing shop)
i already put on two of em on different trucks, and i have 2 old pumps lying around, and could probably find a lot more for no money with mechanics who did the same thing
Old 12-27-2007 | 04:06 PM
  #37
jasonlee08's Avatar
each shop is different. out of respect of the owners and advertisers i am not at liberty to discuss what our shop pays for cores. but i will tell you 500 is too high.
Old 12-28-2007 | 12:57 PM
  #38
12valve's Avatar
but is there a way to sell em or dont they buy cores without selling a pump?
Old 12-28-2007 | 01:23 PM
  #39
jasonlee08's Avatar
oh yeah shops buy cores without selling you a pump. like i was saying ours does but you wouldn't get no 500 per core
Old 05-09-2008 | 01:21 AM
  #40
babyjoe's Avatar
Why the heck are they so exspensive....supply and demand....I hate the system, cummins builds a motor that won't quit and you never have to repair or buy parts for if treated descent, then they find a flaw and they got you by the *****....bull if you ask me....my3sonsracing...hats off to you man.....way to go ...Keep ON Keepin ON!!!!
Old 05-09-2008 | 07:35 AM
  #41
jasonlee08's Avatar
A lot of the biggest reason is for one thing the test equipment from bosch is about 250,000 testing takes about 3 hours rebuild and tear down is about 2 so it takes a while to retest one. Parts are the second. Parts for a VP44 are not cheap. We are seeing more and more vp's due to the fact of the conversion of the old diesel to the new ultra low sulfur diesel and the gaskets shrink and cause them to leak
Old 04-20-2009 | 10:58 AM
  #42
high bid's Avatar
Well, the dead pedal and power loss struck again while towing. Plenty of fuel, 15psi and clean filters. Another issue that has shown up is that when high idle kicks in the truck will die. Does one complete this rebuild process hoping it's just a stuck cyclinder and gasket issue and re-install only to find out it's an electrical part of the pump - OR- does one just buy a new pump? Is there a way for one to test the electronic part of the pump? Any suggestions would be appreicated.
Old 04-20-2009 | 11:07 AM
  #43
jasonlee08's Avatar
Take the pump off the truck and take it to a certified shop that rebuilds the pump and have them test it. Most places will test and tell you what the 44 is reading. If the codes are fatal inside the psg then the pump needs to be taken apart rebuilt and tested. But yes the pump can be tested without being rebuilt
Old 04-20-2009 | 11:20 AM
  #44
high bid's Avatar
ok, thanks. My uncle works at a bosch pump facility. The truck still runs and drives just when towing it cuts out. Will have to take the day off to remove it for testing. I guess, then I can decide to rebuild myself or buy another pump from him at $1k.
Old 04-20-2009 | 11:42 AM
  #45
high bid's Avatar
ughhh, let me retract that...as it's $300 to test a pump. Thinking I might have to just bite the bullet but if anyone has other options please let me know.
