VP puller in Alabama?
Just make one.
What I did was take 2" or 2" 1/4 inches round is better (hockey puck shape). 1/2 thick. Draw a line across it to make your marks where the holes will go. Then measure 1 1/2 inches or 4cm across. then drill two holes a little larger then the bolts you will use 27/64. Then your done. This is why 2 1/4 puck shape disk is better. If you fine you can't get bolts to start into the pump gear drill the two holes one drill size bigger and it should work fine.
1BadDzl
08-15-2004 09:32 PM
