??VP Guru's
??VP Guru's
Do any of you VP guru's know if your fuel gauage is showing around 4# at WOT if it will set the PO216 death code? Mine idles around 11# and around 7# cruising but will drop to 4# WOT. Truck runs great, plenty of power. Don't know if it is lift pump going south or VP. Thanks for any info.
Fuel pressure is ridiculously low considering all of the VP problems. Do you still have the tiny stock lines and restricted banjo bolt? Check out Blue Chip for diagnosis. Check out MWFI also.
Fuel pressure is slightly below the spec, which is 5 lbs WOT. I would star looking for a replacement LP. I would not stop driving, this is not an emergency.
The LP will not set the 0216, if it is present it means that the VP44 is on its way out.
Will pulling my 30' TT shorten the life of the LP at these pressures? Fuel pressure remains pretty much the same at all times except when pulling hard but stays above 5#.
In short, I would buy a replacement and drive normally, towing or not, until I have the time and desire to replace it, or until the LP fails. 5 lbs of pressure WOT is the factory spec. People here love to have 20 lbs but there is information available that pressures over 12 lbs are suboptimal for VP44.
Thanks PaulDaisy for the info. I will drive it normally and don't use wot very much if any. I'll replace lift pump soon but will still enjoy the summer. Thanks again for the good info.
I got intermittent dead pedal so changed the VP after looking for any alternative. Changing was better than paying a tow bill then changing. Search "dieseldanmac vp" on you tube for videos of replacement. It isn't a difficult job, only time consuming and expensive.
You said have 4# of fuel pressure perhaps and your VP is throwing a 0216 code. It really doesn't matter what you do. You will be in the market for a VP and fuel system in the near future. No one can predict how long it will last. Code simply indicates that the time is nearer than it was. I read somewhere perhaps @ bluechip that code with no driveability problems could be run.
You are right. You can drive your truck until you get some other problem with that code. As we used to say in the Ford garage, Drive it and enjoy it!
Best Regards, Chip Fisher
Get rid of the horribly restrictive banjo bolts in your fuel system. Get a Vulcan reloctor/ big line kit for your fuel pump and you will not see less than 12 psi unless your fuel filter is getting clogged.
Oh boy, here we go, all the way out.
The OP did not say he has a 0216 if I read his post correctly? It would be prudent to read the codes on the truck, since the 0216 does not set off the CEL, but unless the code is there, there is no sign his VP is going out.
I have done testing and am convinced that the banjo bolts, even though restrictive, are not restrictive enough to cause lack of flow to the VP, at least not with low power mods (<500 HP I would say). Going to 1/2" lines and open fittings is a feel-good measure, and while it does not harm anything (other than your wallet), it is no necessary.
Haulin_in_Dixie
15
09-06-2005 06:08 AM
