Vibration Help...
I have the same problem currently. Had a bad vibration at 65+mph but just dealt with it for a little while because tires where about to be replaced anyway. Just for info they were Mickey Thompson Atz 285 75 R16 and I got about 60,000 miles out of them. Anyway a guy in my area had some Mickey Thompson Atz 305 70 R16 for sale off of his superduty because he lifted it and put larger tires on. Anyway they have about 80% on them so I put them on and balanced them at my buddies shop. Drove it and vibration gone. Driving it 3 weeks now and yesterday vibration is back, and its like it never left, exactly the same as it was before. What gives?
1) U-Joints - remove all load on the shaft to tell if good or bad.
2) Carrier Bearing - there is a little play in the carrier bearing, but nothing excessive
3) Drive Shaft - bent or dented
4) Shocks
5) Tires - just cause they balance doesnt mean they are good... i found out the more expensive way...
6) T-Case Output Shaft Bearing
7) Pinion Bearing
there are more items if you probelem is more death wobble. where do you feel the vibration?
Seems like up front, I have an aftermarket track bar (adjustable) have recently replaced tie rod ends, and had a carrier bearing custom made by Driveshafts Unlimited. Pretty sure that the driveshaft isn't bent, U-joints check ok. The only thing that has changed is that last weekend I removed the front tires to install new front brakes and seems like the vibration started after that. I did not do anything different when tightening my wheels down, steel cragars, and as I said I had this vibration before so I know I don't have a wheel tightened wrong. This weekend I am going to try and rotate the fronts to the back and see if the vibration moves.
If you put the tires back on the opposite side they came off of then it could cause a tire wobble. I dont move tires from side to side when I rotate unless there is less than a couple thousand miles on them otherwise it always seems to cause a tire balance issue. A tire shop will say thats not true.
I switched to stick ons for this reason.
Thats a fact. And to add to that, tire shops would much rather use the clip on weights because they're cheaper and easier than the stick on weights. I went round and round over this as my weights kept flying off shortly after leaving the tire shop. After complaining that this was becoming very inconvenient, they'd want to try "this" type or "that" type so I finally demanded that they try stick on's and now no more weight problem. Want to see a tire wear funny, then run them out of balance for a few thousand miles.
I looked at the fronts and I am missing the weights that were mounted on the inside of the wheels when I had them balanced. Didn't have much weights on them but might be enough to cause my problem?
dodgedsl03
01-18-2007 10:08 PM
kyle@ftlb
02-27-2004 10:24 PM
